1989 22RE will not Run Right NEED HELP!!!
Old 01-29-2013, 03:17 AM
BUTTERBEAN356's Avatar
When You start the truck up it will idle fine you give it fuel it acts like its running out of gas. I have change
Plugs
Plug Wires
Pickup Coil
Bottle Coil
Clean intake and New Gaskets
New Fuel Filter
Fuel Treatment
Air Filter
When it warms up you give it a quarter of Throttle it will act like it wants to quit but from half to full throttle it runs Fine.
I Notice when you try to pull out it barely will highest gear you can get it up to is 2nd and that's it feels like something is holding it back.
Old 01-29-2013, 03:45 AM
BamaYota1's Avatar
1. Pull codes.
2. Check afm.
3. Check tps.
Did this just start, or has it always been like this?
Old 01-29-2013, 04:20 AM
dtroupe18's Avatar
Did you try adjusting the idle RPM's?
Old 01-29-2013, 06:43 AM
Buck87's Avatar
Originally Posted by BamaYota1
1. Pull codes.
2. Check afm.
3. Check tps.
If you need instructions on how to do these tests go to :
http://www.4crawler.com/4Runner.shtml
Old 01-30-2013, 04:32 AM
I adjust the idle on it does fine now when giving it fuel Everything is Normal, But when you pull out it Lugs down bad still slow got a hold back to it. I Have no Computer to pull up any codes yet when i pulled the TPS wire off the engine it picks up idle when I plug it back in the idle slows Down does that mean its bad or maybe going out?
Old 01-30-2013, 05:17 AM
Buck87's Avatar
read^^^^
follow link, click on repairs, read and learn about TPS and AFM
Old 01-30-2013, 05:51 AM
BamaYota1's Avatar
Do a search on how to pull codes on a 22re. You don't need a computer. Search is your friend. It keeps you from saying stupid stuff that makes it obvious you are ignoring all the help people are trying to give you. This makes it much less likely people will help you in the future.
Test the components the way the fsm tells you to. Some have adjustments, like the tps. If it is out of adjustment, replacing it with a 100 dollar part won't do any good if you don't know how to adjust. A 22re is one of the easiest engines there is to diagnose and fix, but you will have to learn to follow directions and procedures.
Colington
03-08-2020 09:51 AM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
87turboPA
07-09-2015 05:58 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 1989 22RE will not Run Right NEED HELP!!!
