1988 Toyota Pickup ECU Question
Old 03-15-2009, 06:01 PM
jnel5051's Avatar
I have a 1988 Toyota Pickup 4x4 with a 2.4re motor and a five speed trans. I am trying to find a ecu for it but not for sure whatr one I need. Part of the numbers are rubbed of the cover. Does anyone know what the right one i need is or where i can find out what the right one is.
Old 03-15-2009, 07:58 PM
annoyingrob's Avatar
any ECU out of an 84-94 Pickup will work
most 84 (any 84 without a vacuum advance distributor), and all 85 Celica ECUs will work too.
Auto and manual ECUs will both work with a 5-speed.
Old 03-15-2009, 08:07 PM
874runnersr5's Avatar
www.toyodiy.com can help you with finding part numbers for ecu's
Old 03-15-2009, 08:11 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
You can also send a pm to DeathCougar, a member here. He works at a Toyota/Lexus wrecking yard in Wa. He knows his stuff, and might have what you need/looking for at a decent price.
Old 03-15-2009, 08:13 PM
abecedarian's Avatar
it's not necessarily true that any ecu would work.
what about the ecu's for auto's which had the trans ecu integrated?
what about the difference between peak-and-hold and saturated injectors?
what about the difference between the ecu's on 22r and 22re engines?
Old 03-15-2009, 08:19 PM
22R ECU? You mean there's a computer controlling the carb?
As for the integrated auto ECU, was there ever a 22RE with an integrated transmission ECU?
And as for the injectors, AFIAK, the injectors were all the same, but feel free to prove me wrong.
Old 03-15-2009, 08:25 PM
doesnt the 22r have a ecu still?
edit, nevermind.
Old 03-15-2009, 08:27 PM
something has to control the timing.
Old 03-15-2009, 08:30 PM
and on another note, when I was having issues with my 88 a year or so ago, during the troubleshooting process I found a dismantler willing to let me try out parts... and I found out the ECU from one particular 91 wouldn't plug in to my 88... literally wouldn't plug in- the plugs were different but another 91 on the lot had an ECU that would plug in... didn't fix the problem though. (was the igniter).
Old 03-15-2009, 08:37 PM
well, some 22Rs have vacuum controlled distributors
I didn't know that some had electronic timing.
Old 03-15-2009, 08:46 PM
In the trucks, all 22r's should be electronic ignition and have vacuum advance / retard. All the vacuum unit does is move the pick-up plate.
Old 02-05-2013, 10:11 AM
85celicagthatchback's Avatar
i know this thread is old but figure id shine light on injector differences. 82-87 have the same plug and same resistance 3.5ohms so those ecus will work together.88 is a yr of its own it uses 89-95 injector plugs but uses close to the 82-87 resistance 10ohms but is still higher. 89-95 have high rsistance injectors 13.5ohms so not all 22re ecus will work in place of each other
6th Gear
19
12-10-2019 07:31 AM
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
zytra
06-24-2015 08:14 AM
Quick Reply: 1988 Toyota Pickup ECU Question
