1987 Pickup Cherokee Coil Spring
Old 10-01-2012, 06:47 PM
frm_808's Avatar
Over the weekend I finally decided to go ahead and do the Jeep Cherokee Mod, Similar to the "ZUK" mod. Grabbing information from fellow members, I used a 1995 Jeep Cherokee front coil springs to do this mod. It was more of a pain to remove the springs from the Jeep than it was to install it on the Toyota. This was from a Pic-A-Part Junk yard in Las Vegas, costed me only $10 for both springs.
Tools:
Basic tools
Spring compressor
Cut off wheel or saw for cutting the spring
Car lift or Jack and Jack stands
The springs are approx. 18" in height/length. Seen below.
Here's some pics of my truck before the springs go in. I have a 3" body lift from the previous owner, which one day I do want to remove and go to a susp. lift.
I also put a level gauge on the rear of the bed to see how much of a difference it made. It was pretty dead on level but the leave springs were pretty saggy as shown in these pics below.
DRIVER SIDE
PASSENGER SIDE
APPROX. 37" FROM THE GROUND TO THE FENDER WELL
Then I used a cut off wheel to cut the springs down to 14" just to see how much higher it would sit. You could always cut off material, but can't put it back on.
Now its sitting way too high, and pretty much maxing out the OEM suspension.
39" 11/16ths
Almost 3" inches in lift. I coult barely bolt on the shocks as it was maxing them out. So I removed them back off and cut another 2" off
After installed and settled down, you could still see the difference.
At 39", I may invest in getting longer shocks for the rears.
Old 10-01-2012, 06:48 PM
frm_808's Avatar
Hopefully this will also help some that have questions on this mod as well.
Other helpfull links:
https://www.yotatech.com/forums/f116...pickup-255628/
https://www.yotatech.com/forums/f116...agging-255729/
https://www.yotatech.com/forums/f166...arison-246600/
https://www.yotatech.com/forums/f116...uk-mod-215876/
Old 10-02-2012, 12:03 AM
combatcarl's Avatar
That just might be my weeekend project. Before the weather starts to turn...
Old 10-02-2012, 02:16 AM
rokblok's Avatar
What, if anything, are you using to retain the springs to that location?
Old 10-03-2012, 05:52 PM
frm_808's Avatar
rokblok--- nothing is holding it in place but pressure. Even if you articulate it enough with this stock susp setup, the springs should pop out as the top portion is a pretty snug fit. you would need a pry bar to pry it down, then a spring compressor to pull the spring out of place.
Old 10-03-2012, 06:21 PM
Luvmeye22re's Avatar
So are you going to wheel this thing or are you using this for load bearing purposes? It seems like it would KILL your articulation but that's just speculation on my part. I'm not talking smack. It just seems like the spring rate designed to hold a (heavy) inline 4.0 or a jeep v8 (5.2 or something??) would be WAY too overkill for a toyota bed that two guys could carry 100 feet without breaking a sweat even if you cut them shorter.
I'd be interested in seeing how that thing flexes up.
Old 10-03-2012, 06:29 PM
frm_808's Avatar
luvmeye22re--- I wouldnt think this setup would let you flex as great as it was, this is just a bandaid repair for the sagging rear leaf springs. When money comes around, itll be SAS and different setup in the rear
Old 10-03-2012, 06:57 PM
I smell what you're steppin in 808, I was just trying to understand the purpose. I've been known to bandaid things in the past
Old 10-07-2012, 11:22 AM
frm_808's Avatar
No biggie, just trying to help others with this saggy rear end
Steven
MO transplant
04-23-2023 11:58 AM
06-01-2021 01:51 PM
sandyota
02-04-2021 11:16 AM
shar
07-09-2015 12:38 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: 1987 Pickup Cherokee Coil Spring
