1987 22r wont crank
Old 11-06-2011, 07:16 AM
rfs002's Avatar
1987 22r wont crank
Can't seem to figure out what is going on with my 87 22r maybe someone can help me. it starts up fine when the engine is cold but when the engine is warm it will not even crank-all of the dash lights come on though. It has a new battery, new starter, new starter relay, new positive and negative cables. I've seen some other problems like this posted here but I can't seem to find a solution. Has anyone had a similar problem or have any ideas??
Old 11-06-2011, 07:26 AM
skypilot's Avatar
Ignition switch. power to the soleniod goes through the switch. If you want just rig a new wire to send +B to the solenoid from a new switch inside the cab.
Drove me nuts too until I recalled the mantra of the 60's. +B to second on the coil, and a screwdriver on the starter. Off you go.......
Old 11-10-2011, 04:11 PM
rfs002's Avatar
I appreciate the help. I put in a new ignition switch and it worked for a couple of times but now I'm back to the same problem. Drove around for a bit then shut it off, tried to start it and nothing... anything else it could be??
bigjstang
08-25-2021 12:41 AM
sandyota
02-04-2021 11:16 AM
coreyedwards7611
01-16-2016 06:38 PM
Michael oaks
07-27-2015 11:47 AM
redneck17
07-17-2015 07:44 PM
Quick Reply: 1987 22r wont crank
