120amp Jaguar Alternator Upgrade **HOW TOO**
Old 03-05-2021, 01:36 PM
  #81
Steven Bernard's Avatar
Originally Posted by chris514scott
No such thing as a stupid question... Yes the plug matches. That was one of the main reasons I went this route, that way i didn't have to mess with my harness or fab up a new plug.
This Alts are NOT the same size. The Jag is significantly bigger and heavier but the mounts are the same. This alt will barley clear the radiator hose because of its larger size, but it will clear.
I went with your suggestion, but my mechanic said the the plug is different?
Old 03-05-2021, 01:59 PM
  #82
stanz's Avatar
Don't know what to tell you... mine was an identical plug and have ran it for years with no issue.
Old 03-05-2021, 02:02 PM
  #83
stanz's Avatar
Post pics of the back of the alternator you picked up
Old 01-31-2024, 05:18 PM
  #84
davefarr's Avatar
Bringing this back from the dead......regarding the internal voltage regulator mentioned on post 57- are guys just plugging this alternator in and going or are they replacing the regulator/plug assembly ?
Old 01-31-2024, 06:49 PM
  #85
stanz's Avatar
It's plug and play... both alternators have the same Denso plugs and the terminals are the same. I only had to taper the pulley for it to go in.
Old 02-01-2024, 04:42 AM
  #86
davefarr's Avatar
Are the terminals the same? my reading indicates that one terminal is dead/blank on the Jag denso...... is there no functionality loss (dash gauge?) or something.
Old 02-09-2024, 08:09 AM
  #87
dfarr67's Avatar
S terminal, sense is deadheaded on the Jag alt. Internal sensing vs oem external.
muddpigg
11-19-2017 01:19 PM
sploople
02-04-2015 10:06 AM
chris514scott
05-24-2012 10:09 AM
qdude79
08-05-2010 05:07 PM
pattycakes77
09-09-2009 08:10 PM
Quick Reply: 120amp Jaguar Alternator Upgrade **HOW TOO**
