120amp Jaguar Alternator Upgrade **HOW TOO**
Old 05-18-2012, 12:58 PM
ChefYota4x4's Avatar
Originally Posted by chris514scott
Thanks for all the compliments guys. I just want to try an contribute as much as I take from this site.
Today's project is putting 2000 celica bucket seats in the truck. Got a really nice pair for $100. Thinking of doing a write up but don't know ow interested everyone would be since is specific to a certain kind of seat.
Celica; Nice Seats...... but the mid 90's ones were too small for me(narrow in the bolsters). I wonder what the 2000 seats look like, INTERESTED! Lol.
I swapped in a TC seat(VERY nice quality, but too dense of a foam for me)... So, eventually just had my Orig SR5 87 4Runner seats welded/repaired a lil bit and slapped it back in, using 1" HD foam from Joann's Fabrics in spots, etc. WAY comfy now, lol.
Old 05-24-2012, 10:50 AM
chris514scott's Avatar
As promised...Here is the info on the celica seats
The seats took little modification. Drilling a few new holes and making two brackets out of angle iron. Overall it took me about a half a day.
Seats re fullly adjustable and by far my favorite mod so far.
Below are pics. If anyone wants more specific details about them i will be more than happy to take pics of the exact mounting.
Custom mounting brackets.
Old 05-24-2012, 11:28 AM
Elton's Avatar
for you 3.0L guys look up cs144
Old 05-24-2012, 12:21 PM
vasinvictor's Avatar
Good write, now somebody please fix the spelling of the thread title!
Old 05-24-2012, 01:09 PM
  #25
NO this is a "How ALSO" thread. NOT a "How To" thread. LOL
Im so embarressed. Thats what i get for doing that late at night with little sleep.
Old 05-24-2012, 02:12 PM
  #26
Team420's Avatar
Originally Posted by Sin
My thoughts exactly ... wonder if it'll work on a 3.0?
Hmmm... Someone correct me if I'm wrong... but I coulda swore the stock alt in my runner was 130 amp.... If thats the case, this swap would not help us at all....
Old 05-24-2012, 03:03 PM
  #27
ToyoTech559's Avatar
i wanna say stock is only 90 or 110
you can get a 160 here
http://www.northwestoffroad.com/parts/alternators.php
i dont know how much
or a 130 from here
http://www.lceperformance.com/High-O...-p/1080012.htm
Old 05-25-2012, 10:01 PM
  #28
2big4arunner's Avatar
my 1993 4runner is only 60 amps.. I dont know how it could run what it runs but it does. Rockauto has a few listed to confirm this thought. I have been trying to figure out how to get my hands on a turbo supra alternator. It should be a 100 amp model from 1993 that should just bolt in.. no mods on the v6 at all.
Old 05-27-2012, 06:18 AM
  #29
eric08021's Avatar
Well I got that alternator. And I have a 94 22re, it bolts in....but the plug is not the same. Have to call a dealer and see if they have one
Old 07-12-2012, 11:53 AM
  #30
eric08021's Avatar
Hey do u know where I can look up the jag alternators that would fit my truck? That alternator does not have the same plug as my truck. Thank you
Old 07-12-2012, 12:35 PM
  #31
Eric, is there a possibility that a yard around you might have a spare fried alternator that you could YOINK a plug off?
Old 07-13-2012, 01:20 PM
  #32
eric08021's Avatar
Ok I found that the alternator fits the plug from the tacos in the 80s. Not any in the 90's
Old 07-13-2012, 01:41 PM
  #33
NickMiller's Avatar
FYI, pre-1995 1/2 trucks were just referred to as a pickup, the Tacoma (Taco) name wasn't used until AFTER 1995.
/end rant
Sorry, continue with thread
Old 07-17-2012, 08:54 PM
  #34
My truck is a 1990 pickup and the plug was exactly the same as the Jag alt, plugged right in. IDK why mine would be different???
Old 07-17-2012, 10:33 PM
  #35
BirdDogg's Avatar
OEM alt is 60A max
Old 07-21-2012, 02:40 PM
  #36
MortonPhotographic's Avatar
My alternator finally gave out and took the belt with it. So I'm without a vehicle but I got my hands on a Jag alternator... But my pulley won't fit. Having one of those days
There's a huge difference on inner diameter of the two pulleys. Any suggestions?
Old 07-22-2012, 03:57 AM
  #37
dixiemuddtoy's Avatar
Use a drill press and a step drill bit...and ONLY do the inside of the pully, you step it out to the size where it will sit relatively flush to the alternator without interfering with any functions, and when you impact on the factory pully it will stay tight.
**be careful not to go too far...the pully will not work backwards, and you will have to source a new pully**
My install went pretty much flawlessly, however be sure to plug up the alternator BEFORE mounting to the brackets...the hard water line makes it near impossible on the 22re's.
One thing i noticed with my alternator (from a junk yard) was that idle Amps's were a little low...I'm thinking this because the yota pully is larger than the factory Jag serpentine pully?
IS there a company that makes a small diameter factory V-belt pully to bolt up to these alts to turn more RPMs / higher Amps at idle speeds?
Maybe the alternator I have is just wore out....
Hope this helps the 22RE guys out
Old 07-22-2012, 11:30 AM
  #38
Dixie... The hard water line/lower hose supply line from the block... Where the alternator is... It's really tough to get this alt. in due to that? You said, "Plug it up"... meaning? Sorry man... not trying to be dense. Curious, ...but I just don't know exactly what you mean. (it's been a rough.......year! haha). Thanks, Dixie... BTW, love the lights!
Old 07-22-2012, 12:08 PM
  #39
Thanks Dixie!
Chef, he means plug the 3 pin wire harness into the alternator before mounting it to the engine. It's a tight fit to get it plugged in even on the stock alternator.
In favor of having a truck to drive, I gave up, returned my Jag alt., and got a lifetime Toyota alternator from Pep Boys. It was $83 and I found a $20 off $100 coupon so I got some supplies too. Bottom line, it was cheap and fast, but nly 60 amps. 8(
Oddly enough even the stocker gave me a few small hedaches when installing--but not so many that I couldn't get it done. The truck runs way better now, my old alternator had a horrible drag.
I will just uprgade the alternator to the Jag, or do a Chevy conversion when I need it--and have the time!
Just for anyone doing the Jag install... I got my Jag alt. from Pep Boys and feel it was a good deal on a lifetime warranty alternator. For some reason the spindle for the pulley was larger. Maybe this is because they replace everything when they remanufacture it, so they use different parts. Maybe a cheaper reman that only replaces wear parts will retain the stock spindle? I dont know for sure. Either way, keep pulley fitment in mind when sourcing your alternator.
Dixie, I agree that the factory serpentine pulley on the Jag is what is affecting your idle amperage. I don't see why a smaller V-belt pulley wouldn't solve this issue.
Old 07-22-2012, 01:43 PM
  #40
Morton.... (how you been, btw~! ) ..... I was wondering if you saw where I asked... What about the MR2 Alternator? Isn't it 120A and plug and play.... for the most part? I will search it out, but I see them all the time at Pick'your'part,...and with a brush replacement, maybe a lil work, I'd be done, VOILA! haha. JK, most things aren't that easy, at least very often.. But why not look into it, right? haha.
Quick Reply: 120amp Jaguar Alternator Upgrade **HOW TOO**
