.020 over 22rte running lean
Old 08-21-2010, 03:28 PM
boosted4wd's Avatar
so i have about 1,000mi on a .020 over rebuilt 22rte and i just pulled the plugs for the first time and it looks like it is running fairly lean, so am wondering how many teeth i should move the afm gear? P.S. the truck is stock other than being bored .020 over and LC Engineering EGR blockoff plates!
Old 08-21-2010, 04:08 PM
greatskiiiier's Avatar
dont move it at all, mine were really white so i put a wideband on it (was ganna wait until funds were in surplus, but gatta do whatchya gatta do)
and if anything my motor is running rich
idle- 14.7
normal driving- 14
1-3lbs of boost- 12-13
5-6lbs of boost- usually 11
6.5+lbs of boost- needle sits at 10 with the rich warning light blinking (less that 10:1?)
*all these numbers fluctuate +/- .5
a good forum to join is 22rte-trucks and also look up jeff mosk's site, not the most info in the world, but better than nothing
Old 08-21-2010, 04:30 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
And this is a fully stock RTE, or just an RE with a manifold and Turbo?
Old 08-21-2010, 04:32 PM
Originally Posted by greatskiiiier
dont move it at all
x1Billion... Seems that always ends up with something like, "Need new AFM"...
Old 08-22-2010, 03:13 AM
well if you have a wideband and mark the stock location of the teeth, i think it would be okay, but if you're guessing on how much to move it then chances are something is going to get screwed up
honestly, just get a wideband, i bought mine from glowshift for $152 shipped, cheapest i saw and its got a bosch lsu 4.9 sensor and it literally is idiot proof to install, from pulling out the drill and welder for the bung to test driving the truck was less than 2 hours
and with the wideband you know whats going on not guessing based on the plugs, like i said my plugs were white as can be and if anything im running on the rich side
Old 01-06-2024, 02:47 PM
dopeboy420's Avatar
.020 over is lean
hello I’m having the same issue with my 20 over rte truck same a rebuilt engine damn near everything new also have a lce turbo kit with a gt25r turbo my turbo is red hot on a regular drive down the road every one is saying it’s lean any way you fixed your issue I’m buying a wide band so I can get a reading just curious if you figured it out
Charecter1
11-06-2023 10:08 AM
the1998sr5
15
07-14-2020 08:35 PM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
karbin
07-05-2015 11:37 PM
Quick Reply: .020 over 22rte running lean
