Thermo sensor touching catalytic converter element....s'ok?
Old 03-25-2013, 03:50 PM
StumpyJohnson's Avatar
The thermo sensor on my truck is touching the element on the new magnaflow cat I installed. What do? Is there a shorter thermo sensor out there? I imagine it'll read hot...what will that cause?
Old 03-25-2013, 06:13 PM
frankryzzo's Avatar
Not really sure if it will cause a problem, but you can always space it out a bit. I think an 18mm anti-fouler should fit the bung. You may have to drill it out a bit to accommodate the sensor, but it should give you about an extra inch of clearance. You can find them in the "Help" aisle in pretty much any auto store, and they come in a two pack. I've used these for spacing sensors in exhaust for years, and they always tend to do the trick and stop any codes from being thrown.
Old 03-25-2013, 06:27 PM
You rock!
Blamalam
03-12-2022 07:34 AM
okamikai
04-30-2018 10:19 PM
mussy01
12-13-2016 08:20 PM
09-04-2015 09:27 AM
Gevo
07-29-2015 11:15 AM
Quick Reply: Thermo sensor touching catalytic converter element....s'ok?
