only for those who like mind games: 3.0 plugs in 22Re
Old 07-31-2012, 07:48 PM
bryy's Avatar
I am so stumped and now have to get temp tags
Old 07-31-2012, 08:02 PM
B-Fake's Avatar
I'm stumped, I don't see why those plugs don't work. You could try having someone crank the engine while you have the plugs out of the head but plugged into the plug wires and see if they get spark and compare with the plugs that work to see if there's any difference in spark. Also, I imagine they're the same but, are the contacts on the plugs where the wire connects the same size? If the 22RE plug contacts are smaller the wire won't make a good connection.
Old 07-31-2012, 08:20 PM
James Woods's Avatar
So instead of focusing on the spark plugs, maybe you should try looking for why it is failing emissions right now and then move on to the plugs. Check your timing and make sure that is on, make sure your TPS is adjusted properly along with your idle.
If you find what is making you fail emissions, it may be a connection to the motor running good with one type of plug but not another.
Old 07-31-2012, 08:37 PM
bryy's Avatar
That's a good point I was going off this plug problem being the reason
Old 07-31-2012, 08:42 PM
  #25
B-Fake's Avatar
Good call, set the valve lash too. Those HC levels are pretty high. In my old Geo Metro when I got high HC readings it meant my exhaust valves were burnt out. Easy way to check that is with a leak down tester.
MO transplant
04-23-2023 11:58 AM
Doug4320
03-24-2018 10:11 PM
steve miller
10-10-2015 01:40 AM
Coreyr384
07-10-2015 11:13 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: only for those who like mind games: 3.0 plugs in 22Re
