Mechanical to electric fuel pump?
Old 03-07-2009, 06:31 AM
resiewdub's Avatar
Anyone ever switched out the fuel pump from a mechanical to electric? I just got a weber carb and it calls for 3 psi, which is less than mechanical puts out. I could get a regulator, but why not just go electrical? Could I get a pump from the junkyard, or auto parts store? How would I wire it in?
Thanks in advance!
Old 03-07-2009, 08:45 PM
myyota's Avatar
It would be cheaper and easier to just get a regulator and hook it up, otherwise your looking at buying an electric fuel pump and wiring to make it work, and you still might also need a regulator even with the electric pump, it just depends on how much money you want to spend and how much work you want to put into it.
smthwsn357
05-01-2024 07:28 AM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Mechanical to electric fuel pump?
