headlight issue
Old 01-19-2018, 05:41 PM
Kaenen's Avatar
Can't get head lights to work!
I had these after market head lights in my truck and they worked but then I had no low beams I played with fuses and wiring and then I lost high beams, I thought it was head lights them selves so I bought new ones. Then I still have the same problem fuses are all good relay is good I hear it click. But nothing happens. How do I check for power at head lights? Where else do I check for power and how need truck on road asap!!! My truck is 1991 yota pickup sr5 3.0 v6
Old 01-19-2018, 05:45 PM
Kaenen's Avatar
Originally Posted by 4Crawler
Well then check for power at the headlight relay and for good fuses:
http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
The relay may be clicking but if the contacts are burned or pitted, it may not be sending power out to the lights.
I got no head head lights in the front at all bought new ones and lights and wiring and still nothing any ideas?
Old 01-19-2018, 10:27 PM
Co_94_PU's Avatar
Go to your local Harbor freight, buy a volt meter. Start a new thread. Include photos of the meter. Include details on the lights you bought, brand model number, and any wiring diagrams they provided.
Old 01-23-2018, 02:22 PM
RAD4Runner's Avatar
You read 4Crawlers instructions how to check it?
And you searched for "Headlight Troubleshooting"?
A problem well-stated is a problem almost solved. Put us in front of that truck.
How do we know if you used GOOD after-market headlights? The headlight circuit is poorly-designed; even stock headlights strain the switch contacts; Some after-market headlights use higher power than stock/OEM so they could kill switch contacts even quicker.
And like Co says, go to HF and buy a multi-meter (pls see my signature).
Old 01-23-2018, 06:46 PM
  #25
Kaenen's Avatar
Still
I still have nothing checked power and I have 12V on high beam with the volt meter and have 0V on low. But then when I plug them back in I have no highs even when I have volts going to the head lights. And of course no lows because I have 0V going to the lights.
Old 01-23-2018, 06:49 PM
  #26
Kaenen's Avatar
Like I said to 4crawler I​​​​ still have nothing checked power and I have 12V on high beam with the volt meter and have 0V on low. But then when I plug them back in I have no highs even when I have volts going to the head lights. And of course no lows because I have 0V going to the lights.
Old 01-23-2018, 06:53 PM
  #27
RAD4Runner's Avatar
A picture paints a thousand words. Exactly where are you checking power? Both bulbs will have 12 volts AT ALL TIMES when headlight switch is on. The dimmer switch selects which bulb to connect to ground.
​Also, search headlight troubleshooting.
Old 01-23-2018, 07:07 PM
  #28
Kaenen's Avatar
Ok I'll get a picture tomorrow but it is where the harness for the head lights plug into the factory wiring harness on the truck it's like three holes.
Old 01-24-2018, 06:22 PM
  #29
Kaenen's Avatar
Pictures
That's what it looks like when high and lows come on nothing comes up
Old 01-24-2018, 07:16 PM
  #30
RAD4Runner's Avatar
??? Sorry, English please.
I'll post exact test points tomorrow. Too cold to go out - LOL!
Old 01-24-2018, 07:31 PM
  #31
Kaenen's Avatar
Ok thanks
Old 01-24-2018, 07:55 PM
  #32
RAD4Runner's Avatar
BTW...
I had these after market head lights ...
Many LED lights may not work with Toyota's switched ground headlight system. They are polarity sensitive. DOT-compliant but expensive Truck-lites would plug and play without modification.
Old 01-24-2018, 07:58 PM
  #33
Kaenen's Avatar
BTW...
Many LED lights may not work with Toyota's switched ground headlight system. They are polarity sensitive. DOT-compliant but expensive Truckl-ites would plug and play without modification.
ok I will look into that, they are HIDs
Old 01-24-2018, 08:03 PM
  #34
Kaenen's Avatar
I will also try the other wiring harness I have from my other lights and see if they work in theses head lights.
Old 01-27-2018, 02:18 PM
  #35
Kaenen's Avatar
BTW...
put new relays in and still nothing I'm getting tired of playing with the wiring if, im gonna look and see if.any of the wires got cut somewhere and if nothing I'm gonna bring it in to get looked at. Need the truck asap so I don't really have a choice
Old 01-27-2018, 03:18 PM
  #36
RAD4Runner's Avatar
... I don't really have a choice
Yes, you do have a choices:
1) Let someone else look at it, and possibly mess it up more, OR
2) Look at it yourself.
Disconnect those after-market lights. Check connector pins according to this:
https://www.yotatech.com/forums/f116...ooting-302108/
(Go straight to alternative method - checking across connector pins)
Old 01-30-2018, 06:09 PM
  #37
Kaenen's Avatar
Fixed
It was the hid wiring all along
Old 01-30-2018, 06:46 PM
  #38
RAD4Runner's Avatar
So what did you do to fix it? Fix the HID wiring? Restored to stock?
Old 01-30-2018, 07:03 PM
  #39
Kaenen's Avatar
[QUOTE=RAD4Runner;52389168]So what did you do to fix it? Fix the HID wiring? Restored to stock?[/QUOTE
i went to the auto store bought 9003 head lights and put them in the socket plugged them into truck wiring and now have fully functioning high and low
Old 01-30-2018, 07:42 PM
  #40
RAD4Runner's Avatar
[QUOTE=Kaenen;52389170]
Hmmm... 9003 bulbs? You mean you have conversion housing and not sealed beam?
Confused because you posted this on "84-85 Trucks & 4Runners"...
Quick Reply: headlight issue
