Dowel/guide removal on #1 cam bearing
Old 11-29-2010, 11:28 AM
szafko's Avatar
Hello all,
I have just torqued down the head on my 1994 3vze. During the install of the camshaft, I managed to strip out the thread holding #1 cam bearing on the passenger side. Attempting to fix this with helicoil inserts but, I need to remove the dowel/guide that aligns the cam bearing. How would one go about doing this?
Thank you for helping me out.
Old 11-29-2010, 02:17 PM
szafko's Avatar
Well, it seems I'm talking to myself here LOL. I did manage to get the alignment pins out by using a flathead screwdriver, a hammer & a pair of pliers. I placed the tip of the screwdriver against the outer wall of the dowel and tapped on the end of the screwdriver a couple of times. kept this up all the way around the dowel.
Next, I used a pair of pliers to grab the dowel, twisted left and right until the dowel worked its way out. The dowel is trashed now and is on order from the dealership.
I guess this concludes this thread. If anyone knows of a better way to do this without damaging the dowel, by all means, add to this thread all you want.
Old 11-07-2011, 08:00 PM
SnowDrive215's Avatar
hey man I'm in the same boat as you...literally...I am going to have to find an easier and non destructive way of extracting the dowel. I did see a few photos http://picasaweb.google.com/kevin3vz...83991940116050 from this guys project...how much are the dowels from the dealer?
Old 11-08-2011, 06:30 PM
rokblok's Avatar
I have seen machine shops use bolt cutters to gain the leverage to grab on flywheel dowels. If anything it puts two small "teeth" on the dowel which are easily filed/buffed smooth.
Just a thought anyway...
Old 11-09-2011, 11:58 PM
well I discovered you dont really need to use a helicoil...you can use a longer bolt
Blamalam
03-12-2022 07:34 AM
glowz825
01-25-2022 09:28 AM
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
Iceman4193
08-28-2015 08:43 PM
Quick Reply: Dowel/guide removal on #1 cam bearing
