84 Solid Axle rebuild..w/pictures :)
Old 04-25-2009, 08:57 PM
toyospearo's Avatar
use the search or google
here is a start
http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
http://www.birfield.com/~morgan/tech/axle/index.html
Old 04-25-2009, 09:14 PM
kcpanages's Avatar
so let me get this right........... the cone washers are on the top of the stud holding the plate/steering arm in place? so there is 8 of them. 4 on top 4 on the bottom? or just one on top and one on bottom? sorry for so many questions. im an ol chevy guy. this is my first yota SA. what a differance it is between the trucks
Old 04-25-2009, 09:34 PM
BLKNBLU's Avatar
Originally Posted by kcpanages
where can i find the FSM? what is the deal with the cone washer
Here is one I have posted before
http://www.functionalfab.com/resourc...%204runner.pdf
and here is a sticky I just recently found myself with lots of great links including the one I have above. It puts us all just a couple clicks away from fantastic help.
https://www.yotatech.com/forums/f120...s-info-175794/
On the cone washers, yes, 8 on the knuckles. There are also 6 smaller ones (per side) on the locking/freewheeling hub. I've had good luck getting them out by using a brass drift on the studs that the washers are placed on. Like one of these
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
The brass being softer than the stud, you won't damage the stud, but the cone washers generally pop loose with a couple solid taps. Once in a while you get a stubborn one.
Old 04-25-2009, 09:46 PM
BLKNBLU's Avatar
Knuckle cones under those nuts, top and bottom
Hub cones under those nuts
Old 04-25-2009, 11:01 PM
  #25
kcpanages's Avatar
thanks guys. yall have been a big help. i recon wabfab will be getting an order from me tuesday, and ill be changing my axle assem and rebuilding the knuckle when i get home from puerto rico in a week or so. thanks again
Old 04-26-2009, 07:46 AM
  #26
toyospearo's Avatar
Yes, There are 8 total. 4 on the passenger side top and 4 on the driver side top. There are no cone washers on the bottom of the knuckle arm.
The difference between the trucks is one is a nightmare and the other is a truck!
I own an International (not too different than a Chevy) and it is a nightmare to work on.
Old 04-26-2009, 07:59 AM
  #27
BLKNBLU's Avatar
Originally Posted by BLKNBLU
On the cone washers, yes, 8 per side on the knuckles. There are also 6 smaller ones (per side) on the locking/freewheeling hub. I've had good luck getting them out by using a brass drift on the studs that the washers are placed on.
Not sure what I was thinking. Toyo is right. I'll go edit my post now, lest it throw someone else off.
Old 05-11-2009, 04:51 AM
  #28
kcpanages's Avatar
Thank you to the OP and the other fella's that have helped this thread. i got my front left axle assemly changed with no problems. took me about 2 hours to break the knuckle down, rebuild it and put a new axle in. The problem i found was the birf cup was shattered into 3 pieces, but got it done. Thanks again
Old 02-26-2010, 09:00 PM
  #29
toyospearo's Avatar
nice!!
I am about to do another full knuckle rebuild with wheel bearings.
Old 02-26-2010, 09:26 PM
  #30
Teuf's Avatar
I have n axle I am going to fresh'n up. Thanks for this post...
Old 02-26-2010, 09:31 PM
  #31
toyospearo's Avatar
that one looks like it needs some freshness!!
Post up some pics of the progress
Old 02-26-2010, 09:39 PM
  #32
Teuf's Avatar
I will, I got that axle from a neighbor for free, his farm burned down, 1996< and his 85 woods beater was kinda toasted, so in 2001 he gave it to me, been hangin around since. That was the last thing I put aboard this boat, moving to Ca. I'll take a million pics though. Thanks
Old 02-26-2010, 09:52 PM
  #33
toyospearo's Avatar
from that photo it looks like it is in pretty good condition.
Old 11-09-2010, 05:40 AM
  #34
LifterCatcher's Avatar
Toyo & Others,
Thanks so much for this great thread I just picked up two 85 SA's and will be rebuilding one or both excited to get started and this thread is already helping me understand things.
Thanks
Catcher
Old 11-09-2010, 07:15 AM
  #35
toyospearo's Avatar
Originally Posted by LifterCatcher
Toyo & Others,
Thanks
Catcher
No problem... take pictures!
Old 11-09-2010, 07:30 AM
  #36
Outsane's Avatar
its easier then it looks !
I put it off for a long time, to make sure I would have enough time to complete the rebuild before I would need the rig. I should have done it sooner.
The following users liked this post:
Meatbag (03-18-2022)
Old 11-09-2010, 09:27 AM
  #37
SCToy's Avatar
May I ask where you found a hub rebuild kit? My 81 has a malfunctioning hub. I guess it may just need the little spring and ball, but I haven't taken it apart yet to look. I'll have to do that when I rebuild the axle. I did just discover I had this laying around though
Old 11-09-2010, 10:21 AM
  #38
toyospearo's Avatar
Wabfab has that spring and ball. I would replace that if you get it apart. Makes turning that hub much more easy!
Old 11-09-2010, 11:12 AM
  #39
Outsane's Avatar
spring and ball?
I found a spring in all the grease, I thought it wasn't supposed to be there..
Old 11-09-2010, 05:52 PM
  #40
toyospearo's Avatar
Originally Posted by Outsane
spring and ball?
ahhahaha!
dude you need a new spring and ball!
Quick Reply: 84 Solid Axle rebuild..w/pictures :)
