84' celica engine in my 85' 4runner
Old 03-24-2012 | 06:30 PM
jay604's Avatar
i found a donor celica with on 100k kms, it has a 22re engine and i'm wondering if it's the same 22re that is in my 4runner. Also wondering how much i should offer him for this engine.
Thanks.
Old 03-24-2012 | 07:51 PM
Terrys87's Avatar
Staff
I am putting one in my 1st gen truck somedayyyy. 1986toyota4x4 and Dutchbelly are using Celica motors also. Maybe their threads will help with some questions you may have.
You will need a 4x4 pickup tube and oil pan. But I am guessing it would work for you. I hav a 83 Celica tranny in my 2wd truck and it was a direct bolt in. May not be much help from my end, but it is what I am going to be using.
Old 03-25-2012 | 11:19 AM
85TurboRunner's Avatar
I think the sensors and such will be different. I have an 84 celica harness and ECU and they are totally different then an 85 setup.
I don't know if you can just swap on your 85 intake and call it good?
Seems like it would be easier to just find the correct engine then tryin to save a couple bucks.
Old 03-26-2012 | 08:12 AM
Outsane's Avatar
I swapped the EFI set up from a 84 celica into a 84 runner (carbed)
The wiring harness and ECU are a bit different.
Wiring harness is made with the AFM and battery swapped..
Old 03-26-2012 | 12:17 PM
jay604's Avatar
Nice work Outsane, looks great! I'm gonna go check out the engine in the celica to see it condition, I have a hard time believing that one 22re cant go in place of another. The guy is only asking for $600 for it all so I think its worth the shot.
Thanks
Old 03-26-2012 | 12:23 PM
wyoming9's Avatar
Red face
Just be warned 84 was the change over to the different blocks of the 85 style engine.
Some 84 Celica`s had the old style engine some the new style.
As long as you swap the complete Engines and all the electronics it should not prove to big a challenge.:jessica:
Old 03-26-2012 | 02:39 PM
Outsane's Avatar
thanks but thats no my motor, that is a celica engine bay
Old 03-26-2012 | 03:20 PM
rokblok's Avatar
I thought you had done a complete swap, Outsane... Struts, electronics reversal, etc...
Old 03-26-2012 | 04:08 PM
Thanks
$600 bucks and you think its a good deal?? Used engines that old are only worth the core charge AFAIC.
Old 03-26-2012 | 08:22 PM
85toy4runner's Avatar
nice that engine looks like the older 22r with the dual timing chain , and with fuel injection , sweet
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Peach
07-03-2015 09:30 AM
Quick Reply: 84' celica engine in my 85' 4runner
