84 22r alternator plug
I pulled my alternator and all the wires were messed up and I'm not sure where they go back in the plug, does anyone have a picture of there plug with the plug wire colors showing where each wire goes?
I've searched and can't come up with anything helpful.
Thanks that might help but I would still really like a picture if anyone has one? I'm pretty sure I have the L shaped 3 pin connector. Here pic of what i have.
This is the plug and the back of the alternator
These are the wires that go to the plug, its hard to see the colors but one is green, one is yellow, and one is yellow with a black stripe
Did you ever figure out which wires went where? Having the same problem. Wires melted out of wire hasp. Need to reconnect but can’t find wiring diagram. Thanks
You prolly dont need this anymore but here is a picture from my harness web. I have a 1984 Toyota Pickup. Isn't great pic but you should be able to glean what ya need from it!
Now in exchange I would LOVE to have pictures of the both male and female sides of the harnesses that connect to the external IC regulator please!
I'm having charging problems & there is no power getting to the Alternator from the battery. If anyone has a wiring diagram showing the IC regulator it would be very helpful! I haven't been able to find one, just the diagrams from the 1985 where they started using an internal regulator from what I've gathered
The following users liked this post:
RAD4Runner (09-13-2022)
