4.7 transfer case or 5.29 rear which is better choice for trail rig
Old 01-23-2010, 12:37 PM
merace19's Avatar
4.7 transfer case or 5.29 gears which is better choice for trail rig
This question was asked on a local forum and I wanted to know which would be better.
Guy is running 35" boggers. I assumed to suggest the R&P change would be best. Due to the reduced stress on the transfer case and transmission and drive shaft. But others say the 4.7 Transfer case change and keep stock 4.11 gears.
I look at things different because its mostly paper analyzes.
Old 01-23-2010, 12:41 PM
camo31_10.50's Avatar
well, 4.7 t-case and 4.11 gears is "supposedly" stronger because the gears are larger than 5.29's
it depends on what he uses the truck for the most? i'm assuming 35" boggers means it's a trail rig or like 80/20 trail/highway
4.7 t-case gears would help to NOT break anything lol
Old 01-23-2010, 12:44 PM
merace19's Avatar
I was assume 80/20 trail and street driving to the trail. I just see the stresses put on the case with those gears. But have not ran them or never been around any one that has trail ridden then either. Thats why i assumed the 5.29's would move the stress point to the axle shafts and pinion, rather than the Tcase.
Old 01-23-2010, 12:52 PM
SpecialScottie's Avatar
I run 5.29s on my 85 and I havent had any problems. I put alot of highway miles on it too
Old 01-23-2010, 12:58 PM
it's allll about strength, that t-case can handle A LOT more horspower than anything in that rear axle, and i'd rather break something in the axle instead of the t-case LOL
Old 01-23-2010, 05:48 PM
muddpigg's Avatar
I seen guys running 37's with ultimate duals on 4.10 dedicated trail rigs without issue.
Old 01-23-2010, 05:50 PM
waskillywabbit's Avatar
4.7 w/ 4.10s hands down.
Old 01-23-2010, 05:59 PM
merace19's Avatar
Well I am convinced. Ya'll say the same as the other forum.
Wab can you add WHY its hands down better?
Old 01-23-2010, 06:02 PM
Because I have driven both and have experienced the difference.
4.7 gears make a lot more difference than 4.10s to 5.29s.
Old 01-23-2010, 06:25 PM
merace19's Avatar
What about breakage? And what difference are you talking about? Take it I have no clue on either and I am just getting the info for later use.
Old 01-23-2010, 06:32 PM
spindleshanks's Avatar
That's a myth: http://www.gearinstalls.com/410suck.htm This example uses 5.71s but the principle is the same.
Old 01-23-2010, 06:37 PM
Lower gearing availability where you can change it is more valuable than a static differential gear.
Old 01-23-2010, 06:39 PM
cincy85runner's Avatar
why would'nt you do both? What wrong with having 529 and the 4.7 gear in the transfer?
Old 01-23-2010, 06:59 PM
That wasn't the question.
Old 01-23-2010, 07:04 PM
I know its not. but is that a good alternative. and is there any reason that you should'nt do it that way?
Old 01-23-2010, 07:11 PM
merace19's Avatar
$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$ Broke people around here
The following users liked this post:
jabrown1095 (05-17-2021)
Old 01-23-2010, 07:17 PM
I understand sorry, everyone made it sound like that was a bad combo to have for some reason, and that setup is what I'm waiting to install just wanted to make sure I was not making a mistake.
Old 01-23-2010, 07:19 PM
myyota85's Avatar
i also run the 5.29s and lower transfer gears no breakage yet but i would start with the transfer
Old 01-23-2010, 07:37 PM
merace19's Avatar
Well thanks everyone. Straighten me out on what should be done.
Old 01-23-2010, 07:47 PM
myyota85's Avatar
id say if money was tight then stick with the transfer gears like (wab fab said) but take the build slow and do both.
Quick Reply: 4.7 transfer case or 5.29 rear which is better choice for trail rig
