22RE Valve Adjustment w Go-No-Go
Old 10-16-2020, 03:44 PM
squeege's Avatar
When I've adjusted valves in the past (on old Honda motorcycles) I've always gone off of the "drag" of the feeler gauge. It wasn't until I got this Toyota that I tried Go-No-Go feeler gauges, and I want to make sure I'm using them properly.
For our engines, the gap spec should be .008 intake and .012 exhaust. Does this mean I should not be able to get a .009 feeler in on the intake side (reasonably, without too much force), or that I should be able to get a .009 in, but it would just have too much drag?
I've checked the valves on this engine twice, going off of drag the first time I only ended up adjusting a couple of them, then the second time using Go-No-Go feelers, I found they were all too loose, and I adjusted so that I couldn't insert the next size up (.009 & .013). I still feel like I could quiet it down some. I'm wondering if I was taking the "no-go" part too literally and should allow room for a stiff drag on the next size up, or if this is quiet as it's going to get.
Thanks for any advice.
The following users liked this post:
Damion812 (10-17-2020)
Old 10-16-2020, 03:52 PM
millball's Avatar
When the lash is correct, the tip of the go-no go should pass into the space,(some drag expected) and fail to enter farther when the .002 ledge of the root of the blade is reached.
A happy 22re clatters a little. They are not designed to be silent, as hydraulic lifter engines are.
Tight clearances burn valves.
Old 10-16-2020, 04:38 PM
squeege's Avatar
Thank you for your response. The set of feeler gauges I have has blades with +.001 ledges and others with +.002. Should I be able to get the +.001 tip in, or is it better to only check against the +.002?
Old 10-16-2020, 05:32 PM
millball's Avatar
The .002 ledge will get you plenty close. No worries.
squeege (10-16-2020)
Old 10-21-2020, 05:26 AM
13Swords's Avatar
BTW, those specs are for the engine hot at full operating temp. I adjust them cold (because it's less hassle) but add an extra .002 to each spec. When the engine warms up & gets full hot, I've rechecked the gaps and they are perfect. The metals expand a touch to take up that extra 2 thousandths of an inch.
I use "normal" feeler gauges and adjust to light drag.
Millball is right, 20R's & 22R's are always a touch clattery; it's just their nature.
Lzryde
05-10-2015 01:33 PM
manuk
06-27-2012 01:54 PM
89whitetoyota
02-04-2012 10:43 AM
rcm
12-08-2011 09:09 AM
skinnadoor
07-23-2007 06:07 AM
Quick Reply: 22RE Valve Adjustment w Go-No-Go
