22r carb idle screw ID help
Old 09-28-2013, 07:45 PM
Mr. Spooky's Avatar
Hello, got a 84 with the 22r and I am just trying to figure out what screws are what on the carb. I am guessing the screw circled in red is the fast idle and the yellow is the idle speed?
The FSM diagram I downloaded for an 85 carb has a different labeling than the carb diagram that autozone.com has.
Also I noticed that air/fuel adjustment screw still has the plug on it. At what altitude would that need to be adjusted? I am near Denver so say 5280ft.
Old 09-28-2013, 11:23 PM
Drewman83's Avatar
Hello circle clock wise for less
Drewman83's Avatar
Yellow circle I meant
Old 09-28-2013, 11:26 PM
Drewman83's Avatar
Wat does ur red screw hook up to mine sits there no adjust will Chang the way it runs
tomczaksdiesel
07-26-2015 10:35 PM
keithporter83
07-24-2015 07:37 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: 22r carb idle screw ID help
