1st gen 4Runner FAQ
Originally Posted by pinemind
Never posted mine:
1985 4Runner
1985 4Runner
- 22re, auto trans
- 33x10.5" BFG MT's
- 3" Downey suspension lift
- 2" RB body lift
- nice red paint
I second that! That is a sweet runner!
This is mine.
http://img.photobucket.com/albums/v6...9884Runner.jpg
This is mine.
#25
see the link for a pic before the new tires:
http://tinyurl.com/5znbu
most the big stuff is in my sig at the bottom.
#27
My '85
Here is a pic of my recently purchased '85 4runner. I has been sitting for 10 years so I have a lot of work to do but it only has 81k! Sorry, I don't know how to post big pix.
#28
bought an 87 Tubro 4runner with the original 22rte, new red paint, trail gear tube bumpers front and rear, 1.5 ball joint spacer lift in the front, helper springs in the rear, 31" LTXs, bilsteins all around, front lockers. only 150k ORIGINAL miles!
#30
1985 sr5 stock white 4runner, pwr windows, cruise control, A/C, brown interior . for some reason it lacks the sun roof, did some sr5 4runners come factory with no sunroof ? its got the sr5 factory tachometer cluster
#32
'85 SR5, purchased stock in 2001:
Multiple tops, depending on the AZ time of year:
Where to start?
Optima red-top awesome since spring of 2003
4.88 junkyard diffs
Rear springs up front
Supra LSD in rear, Lock-right in front.
Longfield 27spline birfs (I only run 35" tires)
Single Marlin 4.7 case, twin sticks.
57" mazda rear springs (the hype and rage BEFORE the chevy 63's)
Square front shaft
custom old school crossover steering with ZUK's help.
Always doin' somethin' to it.
Where to start?
4.88 junkyard diffs
Square front shaft
#33
Where to start?
4.88 junkyard diffs
Square front shaft
Where to start?
4.88 junkyard diffs
Square front shaft
#34
Holy Cow! This thread has some of my original posts! DANG!
That same 87 runner has had A LOT of changes, and is now a parts truck for my new 89 1st gen 4runner.
Way to much to list that has been done to the 87, but it went through some pretty good changes: ARB's, Complete DOM steering redo, dual cases, flat belly, bumpers, sliders, gas tank relocation, etc....
The 89 has a redone front frame, a 3.4 L, FJ80 front axle, hellfire fab knuckles, ARB's F/R, coilovers, links, and is still very much under construction.
#35
I ran a 4.7 by itself for a few years. Didn't like it inbetween obstacles: Way too slow. But, on the rocks, it was pretty good. I like duals with the 4.7 a lot better.
#36
#37
On obstacles, just a touch of the gas peddle is needed. But, it sucks between the obstacles, like fire roads, etc. Knowing what I know now, I would prefer 2 stock cases bolted together at least. At the time, I couldn't afford to replace the crossmember again, let alone get the drive shafts re-done.
I went with a single 4.7 case because I bought the whole thing for $250, case and fresh new Marlin gears. I'm always looking for the deals!
#38
so much to list I will be doing a build up but I am waiting till its done this is with the old lift 33s and lockrights...im going arbs 35s and new lift
