1985 22RE Cooling/Temperature Sensor Questions
Old 11-11-2018, 08:52 PM
Co_94_PU's Avatar
Originally Posted by s0ngb1rd378
I’m now told since I have no A/C, it doesn’t affect anything. My problem is I’m dealing with a starting issue and I had to be sure this wasn’t part of it. I will create a separate thread for that. It’s all worth it for this old girl.
One more time, it's the temp switch (TSW, signal to ECU) not the AC cut off (AC cut off hasa different layout with no shroud)...
Old 12-07-2018, 09:09 AM
s0ngb1rd378's Avatar
Fixed Starting Problem
Probably for a different thread, but my starting issue is all fixed on my 86 4Runner. It ended up being my idle air control valve which isn’t on the market anymore, but can be adjusted. I would highly recommend looking at yours if you have one of these old girls. Unfortunately, I threw parts at the problem after I read multiple threads I thought were explaining my problem. Replaced the starter, thermo time switch, had injectors cleaned, and replaced the fuel pump before we checked out the IAC. It’s not hard to pull it off and take a look at it. Check out this thread.
http://board.marlincrawler.com/index.php?topic=36294.0
sandyota
02-04-2021 11:16 AM
adammtb
07-27-2015 11:57 AM
88yodabasket
07-13-2015 01:32 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 1985 22RE Cooling/Temperature Sensor Questions
