Pre 84 Trucks 1st gen pickups
Weber Tech/Tuning for newbies and tuning
Old 07-24-2014, 05:48 PM
Soul_keeper's Avatar
I ended up breaking the baseplate trying to make it seal ...
Put some new gaskets on and was tightening it down, ohh well
I think i'm gonna try the lc spiral adapter, just won't be driving my truck till I get it
Old 07-25-2014, 02:50 PM
gillesdetrail's Avatar
Lc is good if the fuel atomisation therory of the plate works but it's a bit expensive. I'm real happy with my transdapt adapter and it's much cheaper.
Old 07-25-2014, 08:01 PM
I guess being in a hurry kinda limited my options.
You're right on the $$$ plus their shipping is over %20 of the price at Lc
hopefully it'll be worth it
Are you using that transdapt on a 32/36 ?
Old 07-26-2014, 05:42 AM
No on a 38/38, I'm a bit anal about port matching and anti-reversion so I needed whip out the dremel to smooth out the transition to my intake but my intake has been ported too so that might be why. It is also made in a funnel shape and is very tall, which adds more cc to the intake plenum which in turn ''should'' help in the higher rpms, but that is only theory.
Old 07-29-2014, 09:19 PM
  #25
Ok, I got the new lce spiral adapter installed and what seems like a good jet combination.
Default:
Main Venturi 26/27
Aux Venturi 3.5/3.5
Main Jet 140/150
Em Tube F50/F50
Air Corr Jet 170/180
Idle Jet 60/50
Pump Jet 50
New:
Main Venturi 26/27
Aux Venturi 3.5/3.5
Main Jet 145/155
Em Tube F50/F50
Air Corr Jet 170/190
Idle Jet 70/60
Pump Jet 55
Best I can tell with my narrowband o2 gauge i'm right around stoich now for cruise and idle. I might try a 180 air on the pri, but it seems pretty good so far. AFM screw out 1 1/2, idle screw out 2
It pulls great, no bog or popping. The big test will be mpg.
Old 07-30-2014, 06:29 AM
  #26
Awesome, great info, there are not enough jet setup info on here, I will be sure to post mine when I'm done.
Old 08-06-2014, 11:47 AM
  #27
vertumnus's Avatar
Emission analysis
its a tutorial about emissions - helpful for those trying to pass smog testing...
Old 08-18-2014, 05:18 PM
  #28
vertumnus's Avatar
passing air care Vancouver BC---1982- r22-weber 32-36
passed air care and the engine runs better
premium 91 octane gas
changed timing advance to 4deg ( factory recommended 8deg)
increased idle mixture jet up one size to 65 ( from stock 60)
increased main jet one size to 145 ( from stock 140)
idle mixture screw = 1.25 turns out ( failed at 1.75 for air care testing) adjusted after air care cause it seemed to run better to 1.50 turns out....
cold choke set to run ok ... idle screw -- set to idle 900rpm
changed catalytic convertor to 3 way ( better at dealing with most and esp N0x's)
Vancouver auto parts # 608204 was only 100.00 this probably the most influential esp on N0x's ( and was what i needed to be reduced ) everything else was very low already...
NOTE: my engine had all the emissions removed or capped off as well as no air pump or EGR valve...
passed air care in Vancouver Canada with flying colors...
got 30 mpg -- tho really i have to look at that again -- i kinda don't believe it -- i'll do other tests and post... while away on holidays...
stock engine r22 with Weber 32-36
new timing chain and new cylinder head... compression on engine within specs....
with 2 lines running on the distributor
I wana say THANKS to this GROUP and everyone's sharing i found it super helpful!!!! hopefully my posting will help others too :-)
Attached Thumbnails Weber Tech/Tuning for newbies and tuning-vacuum-advance-distrib-22r.jpg
Old 08-19-2014, 08:36 AM
  #29
83Toyota88's Avatar
Really good info here. Subscribed.
Old 08-19-2014, 10:11 AM
  #30
enigmaT120's Avatar
30 mpg? Is that a 4WD? Yes please double check that.
Old 08-19-2014, 05:47 PM
  #31
83Toyota88's Avatar
If this is true imma be buying a weber lol. My stock carb is tuned pretty good but not this good. Beat I have seen on my 4wd is 18mpg.
Old 08-21-2014, 09:43 AM
  #32
enigmaT120's Avatar
I have a Weber and only get about 20 mpg, that's why I was curious if his truck is 4WD. I think the 2WD get a lot better mpg.
Old 08-21-2014, 02:09 PM
  #33
I don't think you can get more than 23-25 mpgs with a properly tuned weber on a healthy engine in perfect conditions with a stock truck.
Old 08-27-2014, 10:07 PM
  #34
Before my rebuild I was able to get 30mpg with both the stock carb and the weber.
Gas mileage between the two was comparable for me with my 2wd 88' ... just a matter of slow and steady acceleration and always using high gears.
Since my rebuild I havn't gotten above 28mpg (usually around 25).
note: i'm usually the guy in the slow lane
Old 01-26-2016, 07:52 AM
  #35
trevorthetrekker's Avatar
An update - The links in the first post no longer work. Here:
Weber 38 tuning: http://www.redlineweber.com/html/Tec...as_tunning.htm
You can also go to http://www.redlineweber.com/ then click on "Tech Information" in the left toolbar for lots of good info.
Also, why the hell isn't this thread stickied yet?!
Cheers!
JonG85
01-18-2023 04:31 PM
ladybugRC
458
08-21-2020 10:41 AM
the_supernerd
10-01-2015 09:20 PM
hiluxinargentina
09-30-2015 05:51 PM
93RedKrawler
09-29-2015 02:50 PM
Quick Reply: Weber Tech/Tuning for newbies and tuning
