Pre 84 Trucks 1st gen pickups
Strange Brake Pedal Feeling...
Old 02-08-2012, 04:57 PM
ledzeppelin3270's Avatar
The other day my brake pedal started to do something strange. As I would apply pressure, the pedal would feel like when ABS kicks in, kind of a fast pulsing thing, ya know? I have no idea what this could be.... do YOU?
Old 02-08-2012, 05:54 PM
sebastianholmes's Avatar
warped rotors?
Old 02-08-2012, 10:46 PM
LinguraDeLemn's Avatar
x2 it could be just warped really warn rotors.. and the only other thing i can think of that it could be is a possible brake line leak or air in the brake lines. check your brake fluid reservoir cap to make sure its on tight with no cracks etc..
Old 02-09-2012, 08:23 AM
VT80's Avatar
Kinked lines can also result in a pulsating effect, and cause rotors to warp. Extreme braking can cause them to warp also through overheating, vented rotors are a good upgrade to prevent overheating.
Old 02-09-2012, 08:43 AM
Sensei's Avatar
[quote=VT80;51867167]Kinked lines can also result in a pulsating effect, and cause rotors to warp. quote]
I'm pretty sure I know your thought process hear but I would like to hear you explain this phenomenom.
Old 02-09-2012, 11:17 AM
I'll check the rotors and lines in the next couple of days.... drove it to school this morning and didn't notice anything. Drove it back home just now and felt it a few times.... strange.....
Old 02-09-2012, 11:41 AM
Leviticus6432's Avatar
mine would do something like that if i was hitting decent sized bumps and braking at the same time... I believe it was that rear load sensing valve thing in the rear doing it to me
Old 02-09-2012, 12:21 PM
blake.nemitz's Avatar
if its the abs and not rotors you most likely have a broken tooth or two on the rear ring gear causing a gap in the speed sensor pickup on top of the diff. happened to me and the abs would make the rrr noise every tire revolution for a split second. pulled abs fuse at the suggestion from wabbit to diagnose the problem. once i pulled fuse the problem went away until i replaced the gears.
Old 02-09-2012, 12:53 PM
its an 83 isn't it? it doesn't have abs does it? ... I thought he was just comparing the feeling to the feeling you get when abs kicks in on a vehicle that is equipped. I could be wrong as I am roughly half the time
Old 02-09-2012, 02:25 PM
VT80's Avatar
Well... When you apply pressure through a line that has been kinked some of the fluid that gets through the kink can get caught on the other side of that kink (the rotor side), and not return full pressure back up the brake line. This can keep consistent pressure on the brake, or if there is dirt/rust/whatever in your brake fluid it can happen intermittently. This can cause your rotors/drums to overheat and warp.
Old 02-10-2012, 05:47 PM
Leviticus, you are correct, I was just comparing the feeling.
theking11863
03-19-2016 09:36 PM
fountain
12-31-2015 06:08 AM
ty1er
08-01-2015 11:53 PM
PopsDad1
07-30-2015 02:21 PM
Quick Reply: Strange Brake Pedal Feeling...
