Pre 84 Trucks 1st gen pickups
no one will smog my truck
Old 01-31-2012, 02:47 PM
foolio's Avatar
i have a 1980 toyota hilux with a 1981 22r and a weber 32/36 for california that i installed. no one will smog me 2 people said they cant smog me with the carb i have. one guy said i dont have enough vacuum hoses... and the other said you can only pass smog with a stock carb... the third said i need to go get a sticker from a referee because i have an engine swap.
Old 01-31-2012, 06:11 PM
funcrazy1's Avatar
Shouldnt have to smog truck is old enough
Old 01-31-2012, 06:39 PM
yotaman85's Avatar
exempt year is '74, you will need to smog it. the last one is right. if you swap a motor (as long as its newer then the model year of the truck) you need a ref to ok it, then you need al the factory smog equipment from the year of the motor and your good to go.. get it checked out.
Old 02-01-2012, 07:42 PM
foolio's Avatar
so is my webber gonna be ok? does it cost money to get the sticker? kinda lookin for someone who will just fudge it at this point i think my trucks been illegal for 2 months.
Old 02-18-2012, 11:32 PM
the_supernerd's Avatar
In California, the vacuum lines have to be hooked up. You will fail with Weber unless it is CARB certified. Having a 22R in a truck that originally came with a 20R will require a visit to the referee as stated above. I believe the smog equipment will have to match the 22R when going to the referee, so you will need a 22R carburetor and matching smog equipment for the truck it came out of.
Ichneumon
09-27-2015 04:21 PM
Chili327
07-11-2015 10:27 PM
MadMax48
07-03-2015 08:26 AM
sonic concepts
07-01-2015 02:33 PM
saphirekosmos
06-22-2015 10:26 AM
Quick Reply: no one will smog my truck
