Pre 84 Trucks 1st gen pickups
My 22R Rebuild - KawaZX636
Old 05-21-2015, 05:22 PM
  #61
unruhsky's Avatar
22RE Inspiration
Kaw - that build is beautimous! Just purchased an '83 with a hillbilly flat bed and stage 3 cab cancer with a weak 22RE. Still drive able but your build gave me inspiration and since it finally will be staying warm I might just start the project. Will look at Your other build thread
Old 02-11-2016, 09:36 PM
  #62
capillix's Avatar
As this is my kind of art, i'm printing and framing this.
Old 05-07-2016, 07:45 PM
  #63
Brookbaby1's Avatar
22r bored 40 over
Just picked up a pretty damn clean late 70's early 80's Toyota pickup.. going to start peicing her back together shes stock .has been bored 40over was wondering if anyone else has worked on this type of engine rebuild . I usually work more with small blocks etc.. anything I should look at particularly when it comes to this rebuild?..
Old 02-25-2017, 02:44 PM
  #64
warmonger88's Avatar
Hey KAWA, I've been scrolling through your build thread and the 22R desmog tutorial thread wondering what you eliminated from your wiring during this restoration. I've desmogged my truck, added a gm 1 wire, and a weber 32/36 recently, but i now have a grip of stuff just hanging around. I'd like to clean up the engine bay of some of this clutter and have been thinking about cleaning up my harness as well. Do you have any photos of what you removed from the harness from your build?
Old 02-26-2017, 02:05 PM
  #65
Old83@pincher's Avatar
While I was scrolling thru your build to see what you did/something looked like apart I noticed some ' non-factory' heater hose routing and hook-up. So it appears you blocked off the stock heater hose manifold and hooked up your heater to the factory thermostat bypass plate (which you used the LCE part) which would normally go back to the water pump. So I was wondering if this caused any coolant circulation/overheating problems, leaking water pump seal etc.?
I'm also curious about that block off plate and if it is LCE intent to put in a plug as you suggested, would that not restrict/block coolant circulation when the thermostat is closed? Perhaps in the tropics of Maryland and Arizona this may work but in the northern Great lakes where the thermostat cycles between open and closed in all months but July I'm thinking it could cause problems.
Old 02-28-2017, 06:50 AM
  #66
Staff
kawazx636's Avatar
If you can rebuild a small block then you can rebuild a 22R - I have built dozens of engines of all sizes and makes, but the 22R is by far the easiest to rebuild and work on.
Start at the emissions control computer and work your way back - You can remove all wires and sensors that lead into it.
My heat was hella hot! No problems with circulation at all with the way I routed my hoses or with the thermostat restricting heat function.
Old 09-21-2023, 03:46 AM
  #67
newschoolers's Avatar
how did you manage to get a wire wheel in all the nooks and crannys on that transmission?!??!
EACOOK1
11
07-08-2016 05:15 AM
8yota6
02-20-2011 09:10 AM
danskelly
06-11-2010 10:23 AM
unclejstoy
05-04-2008 09:26 PM
farmboy
08-13-2007 08:10 PM
Quick Reply: My 22R Rebuild - KawaZX636
