Pre 84 Trucks 1st gen pickups
L50/52 + 20R = Bad News so far!
Old 08-14-2006, 05:43 PM
Ditchpig's Avatar
I went and put my 20R into my truck and bolted it up to either a L50 or 52 with a new clutch and everything all shiny and new. Turned the key and the starter just went CLUNK. The flywheel or something attatched to it was hitting something in the bellhousing. I checked and there were no bolts or wrenches left in there and I've narrowed it down to my clutch arm/release bearing/throwout hub. I dunno if the L43 that I removed the Arm and Hub from have different clearances than the L50/52 series tranny but the clutch pressure plate was hitting the arm and there was NO FREEPLAY on the arm whatsoever with the tranny and motor bolted together. I have the arm out of the L50/52 and I will replace the L43 arm in there, but I haven't got the damned hub... will this work?
Old 10-07-2012, 06:50 PM
Beelaay's Avatar
Did you have to buy longer bolts to go inside of the motor because everything seems to line up I just can't get the bolts to thead on ?
Old 10-07-2012, 07:35 PM
ThatGuy1295's Avatar
got everything up to that.?
Have your tried turning the motor over with a wrench on the front pulley (harmonic balancer) to verify its not the starter at fault?
Old 10-07-2012, 07:56 PM
Beelaay's Avatar
Did that an still nothing
Old 10-07-2012, 08:11 PM
Beelaay. Is that a rock climbing reference?
Clutch fork wont move? like at all? Youd think the trans would be very difficult to mount up if theres that much binding going on.
Old 10-07-2012, 08:55 PM
85toy's Avatar
you have to use the l50/52 arm the l43 one is different. I JUST did this exact swap and i had no problems.
Old 10-07-2012, 08:57 PM
85toy's Avatar
you need to buy two longer bolts, they are the ones on the left and right side of the bellhousing, need to be about 1/2" longer
Old 10-08-2012, 09:42 AM
Beelaay's Avatar
Thank you so much
calderp
Engine Swaps
08-16-2016 05:15 PM
cb'sYOYO
01-07-2016 09:08 PM
Blamalam
08-16-2015 12:29 PM
calderp
07-27-2015 09:58 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: L50/52 + 20R = Bad News so far!
