Pre 84 Trucks 1st gen pickups
Interchangeable body parts between 2wd and 4x4?
Old 10-09-2010, 08:25 AM
BoredOutnJackdUp's Avatar
So There is a local guy parting out a 79 2wd
and i was wondering if the hoods and doors would fit my 83 4x4?
I searched and searched last night and all i could come up with was
the fenders are different. Which is obvious,
and help would be appreciated.
Old 10-09-2010, 06:01 PM
Fossilized
Staff
dropzone's Avatar
your search was correct, the front fenders are the only major difference, they work but just don't offer the flare coverage of the 4WD.
doors, hood = straight swap.
the bed fender flares are the other difference
Old 10-28-2010, 08:47 AM
theboomboom's Avatar
Along these same lines, does anybody know if the 81-83 22R engine is interchangeable between 2wd and 4wd trucks?
The research I've done has only given me information about '84+ trucks (in which the 22R is not directly interchangeable between 2wd and 4wd because the oil pan and oil pickup are different, is this the same case with older 22R's?)
Thanks!
Old 10-28-2010, 06:23 PM
It'll work.
I've heard of guys doing it alot.
Old 10-30-2010, 11:00 PM
peow130's Avatar
Yeah, you can interchange the two engines.
Just change the poil pan and pickup. It's not like it's hard, if you have the engine out.
Old 11-08-2010, 03:58 PM
hyzerponix's Avatar
What about power steering components? Can you take them from a 2wd and put them on a 4x4 that never had PS?
Old 11-10-2010, 11:20 AM
85 PICKUP's Avatar
I cant speak for these early years, but I had an 85' 22R 4x4 that didnt come with power steering but I installed it.
I think I got the reservoir and misc brackets out of a 2wd 87' 22RE at the wrecking yard. I think the gearbox and the pump came out of a 83' (?) 4x4 as I got a pump too, but it mounted different than the 84' and newer trucks.
It was a weird swap. Kinda a PITA, but somehow it worked just fine and only cost around $50 or so. Good luck and if you have questions on the install let me know. It was a few years ago, but I still remember most of how it went together.
The following users liked this post:
dbittle (01-23-2022)
Old 01-22-2022, 11:52 AM
Tuesday's Avatar
Yes I was wondering also about interchangeable body parts and windshields. I have a 1980 4x4 crawler that is needing a windshield and other cab parts but I have looked around a lot and can't really get any info about it. I would like to replace my front floor pans, doors, and Windshield but I am unsure of which years I can utilize for parts. Any information would be a huge help.
Old 01-23-2022, 12:12 PM
slacker's Avatar
79-83 for those pieces
Jmiller1023
23
08-06-2015 07:03 PM
Vargntucson
07-04-2015 12:15 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
Yoda
08-03-2011 03:59 PM
Quick Reply: Interchangeable body parts between 2wd and 4x4?
