Pre 84 Trucks 1st gen pickups
High steer clearance question
Old 02-25-2013, 06:42 AM
Bingle's Avatar
So I want to get my old push/pull steering out and do the upgrade but I want to make sure I have the clearance before I buy the kit. I have read some mfg's say 3" lift minimum, others 4", some say nothing about it. As far as I know, all the kits are the same as far as location/geometry (please correct me if I'm wrong) so they should be the same. I believe I have 3" lift springs, but I don't remember (it's been like 9 yrs) and they have probably sagged some.
What I want to know is WHAT and WHERE is the critical clearance dimension? I assume it's for the pitman so a "top of leaf pack to bottom of frame must be X" at Y" back from center of front spring hanger bolt" or something similar.
Recomendations on which kit to get, or not to get are also welcome. Thanks!
Old 02-25-2013, 02:50 PM
Bingle's Avatar
Also read something about an oil pan clearance issue, but might be a SAS issue. Please, get out your measuring sticks and let me know if I can make this happen or not!
Old 03-04-2013, 06:09 AM
Bingle's Avatar
bump. anybody?
Old 03-04-2013, 07:08 AM
thefatkid's Avatar
Well with basic rough fitting and box placement it looks like I could do crossover with my OME Dakar springs. I might have to trim the inner fender and will have to replace the pitman arm. I don't have any specific measurments like your asking for though. I'm not going to use a complete kit or I should say I'm going to modify a kit to get the best box placement for low lift height.
Old 03-26-2013, 08:30 PM
zembalayan's Avatar
Get the Marlin Crawler 25mm high steer kit; you'll be pleased.
I also have an Aqualu arm that I'd like to try but still have yet to set up with one of my push/pull trucks. I think steering box placement is critical if you use an IFS box. I have wondered about hacking out the DS stock shock mount and replace with a tube based shock mount that straddles an FJ80 or FJ60 forward throw pitman arm. Just thoughts for you.
Old 08-08-2013, 08:22 AM
Utah4Runner86's Avatar
Bump - anybody have anything more on this? I understand OME and high steer has been done, but I'm having trouble finding specifics. I'd love to get my ducks in a row before I start hacking into my daily driver.
kazuya2416
04-05-2024 02:17 AM
glowz825
01-25-2022 09:28 AM
bigjstang
08-25-2021 12:41 AM
coffey50
07-28-2015 10:55 AM
Quick Reply: High steer clearance question
