Pre 84 Trucks 1st gen pickups
Fuel filter location on a 1979 4WD pickup?
Old 03-05-2009, 08:28 AM
MaximRecoil's Avatar
Does anyone have a picture or diagram showing the location; or even a good description? I can't find a fuel filter anywhere on my truck, and I'm beginning to suspect that someone in the past removed and bypassed it. If I'm not just overlooking it and it really is missing, then I'd like to readd a fuel filter to the system, but I'd like to know where it is supposed to be located first.
Old 03-05-2009, 08:46 AM
83's Avatar
I'd take a picture but my camera died last night. I can't even find it in the FSM...that's weird. Too easy to even be in the maintenance section?
I'd have to guess if you're having this much trouble finding it, it isn't there. If you sit down right under your gas cap and look up under the truck, it should be right there, on top of the frame. You should be able to find the fuel lines coming off the top of the gas tank, and if you don't find a filter along them...I guess it's not there.
Ok I found a diagram in the FSM but it won't show you any better than that explanation.
Old 03-05-2009, 09:03 AM
Does it bolt/screw to anything or is it just supported by the fuel lines attached to it?
I'd like to see the diagram from the FSM if you have scanner or whatever, and it is not too much trouble.
kdo58's Avatar
mine on the left front wheel well, it has a a bracket it fits into. I have seen picture of it.
Old 03-05-2009, 09:09 AM
kdo58's Avatar
here is what it looks like.
http://6lug.com/catalog/images/22r%20fuel%20filter.bmp
Old 03-05-2009, 09:13 AM
Island_Yota's Avatar
Mine has two, one near the gas tank on the frame rail and one on the wheel well near the battery.
Old 03-05-2009, 09:14 AM
95yoda's Avatar
look in my thread about underhood gurus. its in the pic listed under number 2. on my 82. put it there.
Old 03-05-2009, 09:18 AM
kdo58's Avatar
this is what autozone says
http://www.autozone.com/Action,locsS...locsSelect.htm
Old 03-05-2009, 10:58 AM
83's Avatar
Keep in mind this is an '83 FSM. I just today learned that some also have them in the engine compartment... I'm guessing this won't help much.
Old 03-06-2009, 04:14 PM
Thanks. I think mine was originally in the engine compartment though.
Here is a picture of my engine compartment. The arrow is pointing at a short section of copper tubing that is joining two sections of hose. Is that where the fuel filter should go? Is that even the right fuel line for the filter to go in?
Old 03-06-2009, 05:14 PM
slacker's Avatar
YUP .. thats it .
Old 03-06-2009, 05:31 PM
95yoda's Avatar
mines there in my 82.
Old 03-07-2009, 04:31 AM
Originally Posted by slacker
YUP .. thats it .
Thanks. I got it installed, along with a makeshift bracket to hold it in place for the time being:
Old 03-07-2009, 07:36 PM
dezrik's Avatar
I have a stock bracket you can have if you pay shipping....
Old 03-07-2009, 09:58 PM
One for the engine compartment? Yeah, that'd be great. Send me a PM with payment information; and thanks.
Old 06-12-2009, 12:49 PM
86TOYO's Avatar
ok now if i could get some help i have a 86 pickup 4x4 im starting to kinda give up on finding the dam fuel filter...im pretty sure it has one just cant locate it...?
Old 06-12-2009, 01:06 PM
4banginRunner's Avatar
22RE? if it is its in the pass side fender well, on the block, above the stater, under the intake
Old 06-13-2009, 09:58 AM
86TOYO's Avatar
hey so if its not there could it be possible my truck doesnt have one and yeah its the
22re version. so fuel injected. anyway cause i just looked there and it was no where to be found...
Old 06-13-2009, 03:04 PM
You sure?
Circled in red is the fuel filter
This is my old truck that had a 3" BL so to gain access to it w/o a body lift you'll need to take out the panel (circled in yellow) to get to it.
Old 06-13-2009, 05:02 PM
slacker's Avatar
just to clear things up here ...
the original thread was = Fuel filter location on a 1979 4WD pickup?
there was NO efi in 79 , 80 , 81 , 82 or 83 .......
dont confuse things here !!!!
Quick Reply: Fuel filter location on a 1979 4WD pickup?
