Bushwacker Fender Flares (1st Gen Pickup)
I think they are still made. I have seen them advertised here and there. Check out some 4x4 venders, All Pro, Trail Gear, LC Engineering, and others-I think you will find them. Good luck in your search and I hope I helped you a little bit.
You have to find one of their dealers or supply houses that have old stock. I just got parts for my 25+ year old Recaro seats from one of Recaro's dealers because Recaro does not produce the parts anymore.
bushwacker hasnt made them for many years .. long discontinued
but as suncomb1 says , get on the phone !! . maybe check some of the wreckers for used as well .. but even first gens in wreckers are sparce
we have fiberglass flared "hi clearance" fenders for the first gens .. also currently making a rear "bolt on" flare to match the front http://www.toyotafiberglass.com
That is good advice! Far too often I've given up hope just because it was listed as discontinued when I could have continued my search for NOS parts.
I just saw Bushwacker Fender Flares listed on Aftermarket Performance Parts.com They list flares for 1979-1983 Toyota Trucks. I hope this info helps you find a set.
direct link: http://www.aftermarketperformancepar...yota&md=Pickup
$400, not bad
it will be interesting to see if they actually have it because when you search bushwacker's site you get this message "No Products found Matching your request."
$400, not bad
i have a set of fender flares on the back but im thinking of getting a MAX 4 CAMO GRAPHIC STRIPE KIT and a set of front fender flares and i would need m fender flares in max 4 camo
here is a link to the stripe kit
http://www.ebay.com/itm/ws/eBayISAPI...m=110802417275
i also have the option of getting the stripe kit in mossy oak break up and painted the flares in break up i will probaly go with break up because is to camo the interior the breakup
http://www.ebay.com/itm/SIX-10-X60-M...item1c2246dee0
Apologies for the late chime in.. Since these flares are the ones I’ve been looking for, & no longer made. I was wondering if anyone had successfully installed a Bushwacker fender flare thats from a newer year generation model pickup, or even a different brand of pickup that’s compatible by wheel well dimensions etc..?
I’ve seem some pre 84 pickups online/Pinterest/YouTube/etc.. with 38-40 inch tires and am wondering how they have those huge flares on them.
Something I’ve been trying to research and find answers to; since it’s harder to find off-road stuff for our generation trucks. Thanks!
06-01-2021 01:51 PM
Steezy96yota
07-06-2015 10:00 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
