| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Audiovox Cruise Control
#2 (permalink) |
Staff
Not too familiar with the pre84 trucks I know on the 86+ trucks the tach worked off a sensor [on the distributor I think] and may have been pre-wired for it my 87 was when I converted it to an SR5 cluster, only thing I had to wire in was Oil press. sensor.... your model may be similar...
Where did you get the audiovox cruise control? is it an electronic one? I'm interested in adapting the controls to use the factory steering wheel switches... can you post the model #info for it so I can chase down a schematic?
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, custom factory centre console, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom carpet, stereo upgrade tinted windows Toyota Hilux... Get in or Get out of the way. |
#3 (permalink) |
NO VSS, looks like you'll have to put on the speed sensor thing on the driveline, no big deal.
Kit says to connect to negative side of coil, should work just fine.
__________________
1998 Tacoma 4wd | 2.7L | 5-speed | Pioneer Head Unit | Michelin LTX A/T's about 10% Tread- Fun Rig I try not to break/DD 1988 Jeep Grand Wagoneer 4wd | 304 | Auto | Pioneer Head Unit | Dual Subwoofer | Maxxis Bighorns 99% Tread- Fun rig I really don't care if I break/People-Hauler/Tow Rig "When all else fails, switch to power tools" -Red Green |
#4 (permalink) | |
Quote:
http://www.audiovox.com/webapp/wcs/s...1067&langId=-1 Good luck. |
#5 (permalink) |
Great, thanks. Will plan to just go with the magnet then. Do you know if the tach wire is coming from the distributor as aviator said? I assume there's something in there because it was an option on the SR5 for that year.
#6 (permalink) |
Tach signal comes from a plug off the ignition coil. You should, under the hood, drivers side, up almost against the firewall, see two plugs coming off the coil. One has stuff plugged to it, one just has a black cap. That's where you connect your tach wire (under black cap).
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock |
#7 (permalink) | |
Quote:
Only thing that might take some time in interfacing with the throttle cable and finding an appropriate vacuum line to tap into.
__________________
1983 2WD Longbed Pickup |
#8 (permalink) |
Si
__________________
#9 (permalink) | |
Staff
Quote:
__________________
#10 (permalink) | |
Hold On, I Think I may have told you wrong.
I am planning to get this for my truck as well so I was looking through how to install it, and I found that it said: Quote:
__________________
#11 (permalink) |
Staff
hmmm... sounds like more research may be needed... do they have a tech support line?
__________________
#12 (permalink) |
Well, I spent about 5 hours and did the install this weekend. It was very straightforward, only time consuming because I had to find wires and plan where to put things. I have an auto transmission so I needed to install the magnet kit. It would be an hour or two less if you only had to connect to the tach. Also the 5 hours included lounging around drinking coffee and BSing with my friend, who helped with the install.
I'm told Audiovox has a very good tech support line (1-800-225-6074) but I did not need it. Once again this was an Audiovox CCS-100 Electronic Cruise Control which I purchased for $90 from Amazon. Mounting the servo next to the ignition: ![]() Mounting throttle cable on existing throttle: ![]() Connecting to throttle linkage with ball cable: ![]() Throttle cable completed: ![]() Blue tach cable connected (this was too easy...): ![]() Overview of servo, vacuum connection, and wiring once cleaned up and routed into cab: ![]() Couldn't get many good under-dash wiring shots, here is tying into the brake switch: ![]() Magnet kit with bracket (possibly not required for manuals?): ![]() Dash mounted controller: ![]() Overall this was a great addition to the truck for $90 and a Saturday morning. I opted to try it without the vacuum chamber and it works OK, but on steeper hills it will slowly lose speed. On level ground or gradual hills it works like a champ. I'll eventually add the chamber but am happy with it for now. I opted to route the controller wiring around the panel, as opposed to cutting a hole in the dash and routing it straight back. This simply required shaving some of the foam adhesive off so the wiring could lay flat behind the controller. One point in the instructions say to connect the throttle wire under the hood, while another point says to only connect to the accelerator pedal. I connected straight to the throttle linkage as shown. Not sure why there is conflicting information in the instructions. I also needed to ground the black wire coming from the controller, the instructions were ambiguous in this regard and it did not work until I grounded it. Any specific questions, feel free to ask. With a multimeter, a drill, and some time, you'll be good to go and cruising in no time.
__________________
1983 2WD Longbed Pickup Last edited by Jeff D; 06-23-2009 at 11:27 AM. |
#13 (permalink) |
nice install...but one thing I like about driving these old truck is not having a whole lot of bells and whistles
haven't wired my speakers back up since I put on tube doors
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#14 (permalink) |
Nice work! If I lived in the flatlands, I might do the same, but it's too hilly here for my underpowered engine to be able to use cruise.
__________________
#15 (permalink) |
Good deal. Ordered mine today and I'll post back when I know if you need the magnets for a manual.
__________________
#16 (permalink) |
Staff
Once I have a little cash extra I may have to do this mod. Thanks for the good write up.
Jeff according to the online inst. manual there is supposed to be an "application" list/manual included in the box does it say anything about installs in the 89-95 trucks with the 3.0?
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, custom factory centre console, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom carpet, stereo upgrade tinted windows Toyota Hilux... Get in or Get out of the way. Last edited by aviator; 06-24-2009 at 09:14 PM. |
#17 (permalink) |
Let me see if I didn't trash that extra list you're talking about. I remember seeing it but disregarded it because it didn't apply to me.
__________________
#18 (permalink) |
Sorry for the delay, I just finished moving. Luckily I didn't trash the manual.
Here are the relevant Toyota pages from the "reference manual". The instruction manual is available online at this link: http://www.audiovox.com/manuals/owners/1284540_OM.pdf. Should be able to click on the pictures for the full size. ![]() ![]() ![]()
__________________
1983 2WD Longbed Pickup Last edited by Jeff D; 06-30-2009 at 06:25 PM. |
#19 (permalink) |
Staff
Wow! fantastic Jeff! Thanks very much... looking at that it would seem that it would be a very simple splice in install for the VSS, Tach and so on but the factory steering wheel switch would be impossible to use since the factory system uses only two wires and a resistor "tree" to control the system through the CCU computer and the audiovox system uses a 4 wire individually switched system. Still a very useful mod and affordable mod. How did you set up the brake/clutch switches? I guess the brake one goes on the brake light switch but you rarely push the clutch to the floor triggering the clutch start switch when shifting regularly... how'd you get around this? Wait a min. never mind yours is an auto right? Guess I'll give the tech line a call...
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, custom factory centre console, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom carpet, stereo upgrade tinted windows Toyota Hilux... Get in or Get out of the way. Last edited by aviator; 06-30-2009 at 06:56 PM. |
| Tags |
| 100, 88, audiovox, ccs, control, cruise, dip, install, installation, instructions, motorcycle, pickup, schematic, switch, throttle, toyota |
