79 4x4 20r weber conversion help
got the weber carb in and have a few quick questions about the hookup. I plan on plugging up all the old vacuum lines. going from water choke to electric. can i just put a switch in the cab to turn on choke? and what to do with water lines? there was an in and an out. should i just hook them together?
Well with doing the hot water bypass on my old trans am and a few others vehicles you just connect them. I'm sure others will respond asap. Also wiring a electric choke in my sting ray I put in a switch iirc.
