20R timing trouble
20R timing trouble
Long story short. I had a friend try to help me out and check the timing on the 20R. Driving home I could tell something was way off. Felt much better before he adjusted it. From what I can tell it he set it to 0, but from what I'm reading it should be 8 BTDC.
My question is how do I determine this?
Looking at my 22R in the garage you can use the timing marks.
My 20R doesn't have something like this, or it has broken off? A quick search found other 20Rs with a similar setup. Early 20r?
Here is where I set the timing. Based on where it was before it was adjusted, and using the 22R as a reference.
Runs decent now, but I'd like to verify everything if possible.
The following users liked this post:
keycw (10-19-2020)
NYHumpinUtah
9
01-18-2019 10:45 PM
