Pre 84 Trucks 1st gen pickups
20R cutting out under 2000 rpm
Old 06-09-2012, 11:05 AM
gambitace71's Avatar
I have a 1980 toyota pickup with a 20R. I was driving to work thursday and everything shut down. The alternator had a short put a new one in and had had the battery tested it was good. wouldnt start after recharging. ran some test and figured out the ignitor module went out. I couldnt find another one so I endedup putting in a gm one. I finally got it started and I went to test drive it and it started cutting out on me. when I start it it will run but every about 3 seconds it cuts out and almost dies then reves back to idle. if I hold it above 2000 prm it seems to run fine but I havent driven it yet. what should I start with next I would rather not replace everything untill it works because im broke but if I have to what should I replace first? thanks
Old 06-14-2012, 03:55 PM
can someone move move this to a section where I can get some help please. thanks
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
Cbr954ryder
07-25-2015 06:32 PM
80Truck
07-24-2015 03:12 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: 20R cutting out under 2000 rpm
