Pre 84 Trucks 1st gen pickups
20R/22R EGR Valve
Old 03-07-2013, 12:12 PM
80banana's Avatar
20R/22R EGR Valve
Can an 81+ EGR valve from a 22R be used on a 80 20R? They look identical. Can't seem to get mine clean enough to hold a vacuum
Old 03-07-2013, 01:11 PM
83's Avatar
I don't have a definitive answer except...one way to find out!
I had some luck soaking my valve in brake cleaner overnight...
Old 03-07-2013, 01:32 PM
80banana's Avatar
Yep, I've filled it up with aerosol carb cleaner and am letting it soak some more. The reason I think that there's something wrong with mine is that when try to pull a vacuum at the egr's outlet (simulating engine vacuum at idle coming from the egr pipe), I can't get a solid reading...just hear a hiss and the gauge drops to zero...so I'm guessing air is leaking around the internal valve/seat or in from the top seal around the internal valve's stem.
Old 03-07-2013, 01:46 PM
83's Avatar
And deleting it isn't an option? Emissions, etc?
Old 03-07-2013, 01:54 PM
80banana's Avatar
Yep, got a smog check coming up
idadan208
09-07-2015 09:06 AM
Scatterbrain
09-03-2015 06:46 PM
montanatruck
07-25-2015 03:45 AM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: 20R/22R EGR Valve
