1983 Blinker Relay LED transition- Wiring Help!
Aloha from Maui, recently upgraded to rear LED lights, which work well but turn signals flash SLOWLY. In attempting to upgrade the old relay I've run into confusion on the wiring. Or, I have the wrong replacement electronic flasher device.
The 3 connectors on the old flasher are labeled L P X and the new electronic flasher is labeled L B E. I'm having trouble with the translation other than L is "Load". Not even sure I have the right device or if anyone else has tried this approach.
I hooked it up with the L and guessed at the other 2, but managed to blow the rear flasher fuse. Perhaps I've fried the new flasher as well, or maybe I have the wrong part entirely.
Thanks in advance for any ideas or guidance!
old and new flasher
old and new flasher
theragingrussian
09-28-2018 07:00 PM
☆OMI☆
10-31-2015 10:54 PM
cgeorge
11-19-2009 03:17 AM
dip1
10-12-2008 08:58 AM
